Activity › Forums › Apple Final Cut Pro Legacy › Import issue I can’t get my head around.
Cal Gordon replied 17 years, 9 months ago 5 Members · 14 Replies
Jeremy Garchow
January 24, 2008 at 6:25 pmAre you sure you have the p2 drivers installed? The footage is good.
Mark Wils
January 25, 2008 at 2:44 am….I’ve gone back and re-installed or tried to re-install the recommended software. This time, when I tried to install the P2PCCard linked from Shane’s earlier video.. that the install fails. I’ve also noticed when I’m pointing the Log and Transfer window to the folder containing the Contents and Last Clip files.. that the Last Clip is grayed… I’ve held up pretty well till now,…now I’m getting frustrated with the whole thing.
Cal Gordon
November 27, 2008 at 5:39 amHi Mark,
Did you find the solution to this importing problem from “log and transfer”? I’m in the same quagmire! Please see.
https://forums.creativecow.net/readpost/8/1012470
If you’ve found a solution, please let me know.
Cal
Cal Gordon
November 28, 2008 at 5:26 amHi Mark,
I’ve encountered the same problem you’ve had regarding transferring footage from “log and transfer.” Were you able to find a solution? Please let me know. I’m stuck right now. There are clips that would transfer, yet there are some that won’t.
Cal
