Activity › Forums › Boris FX Particle Illusion › IMPORT into Pi 1049×576 > EXPORT( render) from Pi as 1052×576? Or even 720×480?
Posted by Graham Bernard on January 5, 2009 at 12:39 pmI have set up ALL the parameters, prefs and proj settings, I can tell to accept and finally render out to the same 1049×576
Results:
A] Uncompressed comes back into Vegas as 1052×576
B] DV Video Encoder comes back as 720×480
I have an issue with A], but why would B] which IS set up as PAL return into Vegas as a 720x480? Surely 480 is an NTSC height?
Anyways, I need assistance with this returning Pi Render.
TIA
Grazie
Graham Bernard replied 17 years, 8 months ago 2 Members · 6 Replies -
Alan Lorence
January 6, 2009 at 12:19 pmSome codecs only work at specific resolutions, and the DV codec is one of them. I’m not sure why you have an NTSC one and not a PAL one, but I think this has come up in the forum before — try doing a forum search for DV PAL or something like that.
Whatever stage size you set in particleIllusion, that’s your output resolution. So if your stage is 1049 x 576, that’s what it is. If it’s coming in to Vegas as a different size, then Vegas is reinterpreting the size based on a different pixel aspect ratio and you need to adjust that in Vegas.
I think.
Alan.
Graham Bernard
January 6, 2009 at 10:49 pm“I’m not sure why you have an NTSC one and not a PAL one, ” – I’ll look . . but that might still not get a solution?
“Whatever stage size you set in particleIllusion, that’s your output resolution.” Sure, agreed .. but ..
“So if your stage is 1049 x 576, that’s what it is.” Well no, Alan, and while still within Pi it comes up with this different width? Do you want a screen grab?
“If it’s coming in to Vegas as a different size, then Vegas is reinterpreting the size based on a different pixel aspect ratio and you need to adjust that in Vegas.” I can READ this in Vegas as I said, but it is revealing the 1052 figure already in Pi. Now that can not be correct?
Grazie
Alan Lorence
January 6, 2009 at 11:13 pmAh, if you’re saving an AVI, some codecs require specific widths (multiple of 4 for instance). So 1049 may not be a valid width for the codec you’re using.
If you’re rendering PNG and still getting the size larger than the stage size, I have no idea.
Alan.
Graham Bernard
January 7, 2009 at 8:19 amThank you Alan.
I am rendering to AVI. I have taken the width from the PREVIEW that VEGAS displays. If VEGAS is displaying 1049 then I would want to bring back as 1049. Doesn’t that make sense?
If you are saying I need to make widths as multiples of 4 what would I need to do to make Pi “match” what Vegas displays?
TIA,
Grazie
Alan Lorence
January 7, 2009 at 4:43 pmSave in the exact same AVI format as the original movie maybe? Or save as a PNG image sequence (that will definitely work).
Alan.
Graham Bernard
January 7, 2009 at 6:59 pmAlan? “Save in the exact same AVI format as the original movie maybe? ” – Where? FROM Vegas or FROM Pi? And the 1049×576 or what?
Grazie
