Activity Forums Maxon Cinema 4D Import image
  • Import image
    Posted by Per Olsson on May 10, 2014 at 3:08 pm
    Hi!
    I have a flower made in photoshop with transparent background. I want to insert this flower into cinema4d for bending it or manipulating and animating it. I want the background to be transparent. How do I do this?
    I tried to export the paths to illustrator and also open the psd file in illustrator and saving them as illustrator 8 file but all I get is a big square equal to the filesize.
    I want to just import the flower. not the background or anything else. how do I do this?
    thanks!
    Brian Jones replied 12 years, 4 months ago 2 Members · 3 Replies
  • Brian Jones
    May 10, 2014 at 7:35 pm
    if it does have an alpha channel, you can use the psd file in the Color and the Alpha channels of the material and put that on a plane object. If you are looking for an object with ‘thickness’, you can bring in a path that defines the shape of your flower and extrude it, if that’s what you were trying when you got the big square I’d have to see the file to see what’s in it.
  • Per Olsson
    May 11, 2014 at 3:14 pm
    sorry but where do I do this? I put the psd file as a new texture but didnt find the alpha channels? or is it maybe something with my flower.psd file i need to correct before in photoshop?
    I attached both my files here:
    7486_flower.zip
  • Brian Jones
    May 11, 2014 at 11:22 pm
    your psd file is good, you just need to go to the Material’s Basic tab and check Alpha to enable it – then you will be able to use the psd file in the Alpha tab that appears
