Activity › Forums › Apple Final Cut Pro › Import image sequences?
Posted by Christian Roth on June 30, 2011 at 4:01 pmDear Forum members,
Is it possible to import image sequences into fcpx?
regards, ChrisSimon Ubsdell replied 15 years, 2 months ago 5 Members · 11 Replies -
Jeff Greenberg
June 30, 2011 at 4:17 pmIt doesn’t look like it sees them.
The workaround is to open an image sequence in QuickTime 7 (which it sees via the file menu) and save it as a QuickTime.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Simon Ubsdell
June 30, 2011 at 4:18 pmNot as far as I know – you’d have to use Quicktime 7 to import them first as an image sequence and then export a movie.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com -
Christian Roth
June 30, 2011 at 7:50 pmThanks for your answers. Works when I save the movie to prores quicktime. simply saving the movie (an thus inheriting the jpg codec with 18mpix) did not work. ended up in a mess finally crashing fcpx.
Simon Ubsdell
June 30, 2011 at 7:56 pm[Christian Roth] “simply saving the movie (an thus inheriting the jpg codec with 18mpix) did not work”
That’s why I said Export not Save As 😉
Simon Ubsdell
Brendan Gibbons
June 30, 2011 at 7:56 pmIn compressor, at the top there is an option to “add image sequence”….
then you can cook it into any old format you require.
Cheers
Brendan
Christian Roth
June 30, 2011 at 8:16 pm😉 yeah. so now i have to figure out how to compose pan and zooms in my timelapse clips. not a job for fcpx, I assume.
Simon Ubsdell
June 30, 2011 at 8:39 pm[Christian Roth] ” how to compose pan and zooms in my timelapse clips. not a job for fcpx, I assume.”
Actually it’s pretty easy to do with the Ken Burns effect inside FCPX – you can’t finesse the keyframes but it would be a very quick way of doing it fairly well.
Simon Ubsdell
Christian Roth
June 30, 2011 at 8:54 pm[Simon Ubsdell] “Actually it’s pretty easy to do with the Ken Burns effect inside FCPX – you can’t finesse the keyframes but it would be a very quick way of doing it fairly well.”
As fcpx won’t import image sequences (w/ proxies for editing, f.i.), my source resolution will be limited to 4K max., if I understand correctly. thus, I am loosing potential to zoom into the picture.
regards, Chris
dp, Austria -
Simon Ubsdell
June 30, 2011 at 9:37 pm[Christian Roth] “my source resolution will be limited to 4K max.”
And 4K won’t be big enough for your needs? How big is your final project going to be?!
Simon Ubsdell
David Battistella
July 4, 2011 at 10:53 amI don’t think FCP 7 ever did this.
______________________________
Believe me. Everything is a lie.
