Activity › Forums › Apple Final Cut Pro Legacy › import image sequence still duration issue
  • import image sequence still duration issue
    Posted by Massimo Croce on August 8, 2006 at 2:13 pm
    Hi to All
    i m importing to FCP an TGA image sequence, setting up FCP steel duration to 1 frame but
    when i drag the folder in to project the stiil duration is 0.
    setting up the duration to 2 frame the imported stiil duration is 1.
    Any solution????
    thanks
    massimo
    Apple Dual G5
    FCP 5.04
    OSX 10,4,6
    Debe replied 20 years, 1 month ago 2 Members · 1 Reply
  • Debe
    August 8, 2006 at 5:29 pm
    If it were me, I’d try to compile my image sequence in QT Pro first and export it with the codec I need for my project.
    Extra bounus there….no rendering in FCP.
    debe
