Activity Forums Apple Motion Import Illustrator Files Unmerged
  • Import Illustrator Files Unmerged
    Posted by Chris Dixon on September 8, 2008 at 3:07 pm
    I’m trying to import a layered vector based Illustrator file into motion.
    When I do it always merges the layers. I’ve tried converting to pdf, but get the same results. Any suggestions?
    Thanks.
    Doyle Rockwell replied 18 years ago 3 Members · 2 Replies
  • Miriam Moran
    September 8, 2008 at 4:07 pm
    I don’t use illustrator, but to import a layered Photoshop file you need to use, from the menu, “File” -> “Import” then select the file you want. You are then prompted for “merged layers” or “all layers” choices.
    Good luck!
  • Doyle Rockwell
    September 8, 2008 at 5:00 pm
    Howdy,
    Illustrator files are imported as a merged PDF. It’s all vector data, so it can be dynamically rasterized, but it’s merged, so no layers.
