import illustrator files no sequence
I have trouble importing illustrator files to motion, it always import them as sequence even if “image sequence” check box is not checked.
Im triying to import several layers exported from illustrator as illustrator files pdf compatible. But motion only sees them as sequence.
The image is a segmented logo, so if I change the name for no sequence name it will be confusing to work with.
What can I do?Thank you.
