Import Illustrator file (with gradients) to AE. –> PROBLEM –> white gradients in AE
Hi everyone.
I have some problem in exporting process AI file to AE.
In Illustrator file I have a lot of layers with gradients.
When I importing this file into Affter Effect, the composition are completely broken. I mean, this all gradients from AI layers are white (without transparency). So It looks like a one big mess and I can’t animate it in AE.
You will see it on the attached pictures.Any ideas? ☹
Here are this pictures:
https://drive.google.com/drive/folders/1E6hy9cJl2DwZYO7YmudDhgweIUrbH7T4?usp=sharingFile from Illustrator and the results in AE after importing this file as a composition.
