Activity Forums Apple Final Cut Pro Legacy Import from DVCAM tape blocky
  • Neil Sadwelkar
    March 9, 2011 at 1:08 pm
    How do the FCP captured Quicktime files look when seen in Quicktime Player? If they are fine, then what’s looking blocky, the picture inside FCP? Check your Sequence quality settings in the RT popup.
    Also, try capturing in FCP over Firewire and set your easy setup to DV-PAL or DV-NTSC as the case may be.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
