Activity Forums Adobe Premiere Pro Import footage notes to new project OR Codec error message
  • Import footage notes to new project OR Codec error message
    Posted by Jay Coleman on January 24, 2013 at 7:58 am
    Aright so I have CS6 and have updated my Premiere to 6.0.3. I am getting the “sequence has missing codecs” or whatever error that is plaguing CS6 users (I’ve been on a lot of sites/forums going over all the fixes). I opened the Adobe Help program and updated everything possible. I’ve uninstalled and re-installed and done the system clean as suggested on the Adobe help page multiple times. I’ve tried making new projects and then tried re-opening mine (apparently this worked for some people). I’ve re-booted my system after every attempt. I still cannot open the project.
    I can however make a new project and import ALL of the footage. This seems strange to me but hey it works. Here is my problem. My producer (the project is a TV show) left voluminous footage/log notes/color coded all of the footage for me in the original project (marking good and bad takes, separating interviews from b-roll, etc.) And I would very much like to be able to access all of those notes, she did this on her machine and I am now going to edit it on my station at home. Is there anyway I can get the footage in my new project to conform to all of those notes. I would think that maybe there is some kind of workaround in Prelude but it won’t open. I keep getting the “LoadLibraryEx Startup.dll failed with error 193:” If I’m correct in my research this is due to a corrupt dvacore.dll file. I tried replacing it with other files of the same name from other CS6 program files but that resulted in a different error so I put the original back and am getting the original error. I performed the scannow function in command prompt and it came up with zilch; said everything was fine.
    I’m close to the end of my rope here and time is running out, I’m on a pretty tight deadline and am also working another full time editing job during the day. Any help on either fixing Premiere so that I can open the original project or moving the footage notes from one project to another would be VERY APPRECIATED. Thank you for your time and help. Also if you know how I can fix Prelude that’s on the back burner but definitely something I need to address eventually
    Jay Coleman replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
