Activity Forums Adobe After Effects Expressions Import folder into After Effects CC by using ExtendScript?
  • Import folder into After Effects CC by using ExtendScript?
    Posted by Loong Yin min on November 22, 2019 at 7:10 am
    Hi, I am trying to import folder by using Adobe Extendscript into AE CC2018. The function should be same as AE import folder function. Please see attachment below.
    Attachment below is result in AE after  “Import Folder” button is pressed.
    I try to using Extendscript importFile() methods to import folder, but no luck so far.
    app.project.importFile(new ImportOptions(new Folder(“C:\\Users\\Username\\Desktop\\type\\line”)));
    After Effects error: File can not be opened.
    Hopefully any AE master can help me solve my problem. Your help in this matter is greatly appreciated!
    Oleg Pirogov replied 6 years, 10 months ago 2 Members · 1 Reply
  • Oleg Pirogov
    November 22, 2019 at 11:41 am
    There’s a native script called “Smart Import” which does that – imports a folder. You may check it out and see, how folder import is realized there. “importFile” is for files (single files or sequences) only and can not be applied to a folder directly.
