Activity › Forums › Apple Final Cut Pro Legacy › IMPORT FCP PROJECTS INTO ADOBE PREMIERE PRO cs4 problems
  • IMPORT FCP PROJECTS INTO ADOBE PREMIERE PRO cs4 problems
    Posted by Drazen Stader on April 9, 2009 at 6:26 pm
    HI,
    I have tried importing my fcp projects via xml into premiere pro cs4.0.1 using method described on this site https://provideocoalition.com/ however I always bump into a problem that crashes premiere pro…
    I manage to import the files through FCP xml…but as soon I select the linked clips on the premiere pro timeline and premiere pro gives me the following notice: Whitfield/Mediacore/Backend/Make/Mac/…
    and after that it adds another one:
    Please check the fcp translation results report for possible issues encountered during the translation…
    I run Mac OSX 10.4.11, Final cut 6.0.3., Premiere Pro 4.0.1, The timeline was an SONY xdcam 1080 25p, HQ
    If anyone has a thought or even a solution what could be the reason for these issue please let me know….
    thanks
    Drazen
    drazen
    Drazen Stader replied 17 years, 5 months ago 2 Members · 2 Replies
  • Dennis Radeke
    April 10, 2009 at 11:48 am
    Hmm, sounds weird.
    A couple of minor observations. It might be some little bug that is a combination of the things you’re running. I noticed that you’re not using the latest version of FCP (6.0.5) nor the latest Mac OS. Assuming you’re using the Sony plug-in to translate your XDCAM to ProRes, which should open up fine in Premiere Pro 4.0.1.
    I always use XML type 4 (never tried the others but 4 has always worked for me). Have you checked out this particular blog video?
    https://blogs.adobe.com/davtechtable/2008/11/new_cs4_and_final_cut_import.html#more
    Not that this is probably going to fix it, but if you can update to 6.0.5, you might give that a go as it’s free.
  • Drazen Stader
    April 12, 2009 at 1:44 pm
    thanks for the tip. I will definitely try installing all new updates and I give it a try…I will let you know the results in the next couple of days…and yes the video you are suggesting it is the one I watched prior to trying out thise scheme…It is a really handy solution for all those who cant afford themselves automatick duck software.
    br
    Drazen
    drazen
