Activity › Forums › Adobe Premiere Pro › Import family VCR tapes to Premiere Pro
  • Import family VCR tapes to Premiere Pro
    Posted by Bearprod on April 10, 2007 at 7:16 pm
    Princess, the wife, has requested that I transfer all of the our family VCR tapes to Premiere Pro…then add titles, music, special effectrs, etc.,….then burn a DVD of the newly created video.
    I have my VCR machine connect to my Intel Dual-core XP Pro machine via a “video capture card”, but can’t get the capture into a format that Premiere Pro likes. I would entertain any suggestions as to another video capture card; software; or whatever it takes to get her off my back.
    Thank-you,
    Peter.
    Mike Cohen replied 19 years, 5 months ago 5 Members · 4 Replies
  • Tom J
    April 10, 2007 at 8:34 pm
    Hi there,
    Just a quick suggestion. Have you considered a Canopus converter? I’ve been using the original ADVC100 for quite some time now and I love it. There is now the ADVC110 which is pretty much the same unit (same great hardware & codec) just a different box basically.
    Anyway Canopus is now owned by Thomson/Grassvalley, here are the specs:
    https://www.canopus.com/products/ADVC110/index.php
    You should have no problem at all using this unit to bring footage AND audio into Premiere Pro.
    Hope that helps,
    Tom
  • Blast1
    April 11, 2007 at 3:07 am
    [bearprod] “I have my VCR machine connect to my Intel Dual-core XP Pro machine via a “video capture card”
    What is your video capture card? And what format are you capturing to?
  • Darren Edwards
    April 11, 2007 at 10:37 am
    If the capture card doesn’t have firewire but your PC does,
    why not invest in a cheapy VCR player which has firewire out,
    and plug that into PPro?
    PPro will merrily capture the video material although the
    capture window won’t let you ‘control’ the VCR player – you’ll
    have to do all the operational stuff like rewinding and
    fast-forwarding on the VCR deck.
    Darren.
    x-gf.com
  • Mike Cohen
    April 11, 2007 at 6:55 pm
    when I do such projects once a year or so, I first manually dub the highlights of each VCR tape to a mini DV tape. Once I have a full 63 minutes on DV, I capture that via my DV camera. That way I have backed up my video to a format which is a bit more robust than VHS, and I can work on the project in Premiere, delete the raw footage and batch digitize at a later date when my schedule permits.
