Activity › Forums › Creative Community Conversations › Import Fail While Recording with Canon HV30
Posted by John Wade on January 17, 2013 at 8:58 pmI’ve just made the switch from iMovie 11. I am attempting to record and import at the same time into an event on Final Cut Pro X. The camera is connected to my Macbook Pro. Final Cut Pro X>File>Import>Media produces the desired result as far as the Canon HV30 appears as a camera found. When I click on >Import I am presented with the add to existing or create a new event, I have tried both options. There is a brief indication that there is importing going on only because the rectagular box says as much but within 2 or 3 seconds the message says, “Camera Not Controllable.”
and there I am stuck.
Regards,
John
MacBook Pro, Mac OS X (10.7.2)Craig Alan replied 13 years, 8 months ago 3 Members · 10 Replies -
Craig Seeman
January 17, 2013 at 11:03 pmYour MBP has a iSight/Facetime webcam as typical. Try capturing from that live and see if it works.
Are capturing to the internal hard drive or external and if external how is it connected?You should update to OS 10.7.5.
As per Apple Tech Specs
https://www.apple.com/finalcutpro/specs/
10.6.8, 10.7.5, 10.8.2
Also assuming you’re on FCXP 10.0.7 -
John Wade
January 17, 2013 at 11:10 pmThe internal camera is recognized and FCPX captures no problem. I also tried via iMovie11. Once again no problems. I am capturing directly to the internal hard drive of the lap top.
I am running OSX 10.8.2 and FCPX 10.0.07.
John
Craig Seeman
January 17, 2013 at 11:18 pmIf the camera is in HDV mode, as a test, quite FCPX, change the camera to DV mode, open FCPX and try again.
John Wade
January 17, 2013 at 11:19 pmAlso, FWIW, based on another thread I deleted two files com.apple.FinalCut.plist and com.apple.FinalCut.LSSharedFileList.plist. Didn’t work though.
John Wade
January 17, 2013 at 11:36 pmI’ve tried in HD normal/24/30 and none work. However, DV normal and wide both work. Not sure what to make of that. Hope you do.
John
Craig Seeman
January 17, 2013 at 11:46 pmSo at least we’ve narrowed it down to HDV.
FCPX has no problem seeing devices since webcam and DV Firewire work.One more test. If you have an HDV recorded tape see what happens if you put a tape in the camera, play it back, try capturing the playing tape.
Canon HV30 is specifically listed as a supported camera too.
https://help.apple.com/finalcutpro/cameras/en/index.html? -
John Wade
January 18, 2013 at 12:46 amI just succeeded in getting an import to work if I have a tape in and hit record on the camera before I begin the import process in FinalCPX.
Craig Seeman
January 18, 2013 at 1:32 amInteresting. Apparently that impacts what’s sent out of firewire in HDV mode. I have a hunch there’s additional data that helps with the GOP based codec being sent.
Craig Alan
January 21, 2013 at 1:31 am[John Wade] “I just succeeded in getting an import to work if I have a tape in and hit record on the camera before I begin the import process in FinalCPX.”
John, I have a related problem. I have about 10 of the HV30s/HV40s. Last year’s Imacs (800 firewire) and 4 to 9 pin cables. No matter what I try I cannot get the Imacs to see the cameras. Yes the footage is HDV. I have tried different cables (though all the same brand bought at once) different cameras different Imacs. The ports on the IMacs work because they do recognize drives connected to them. I have no other devices that use 4 to 9 pin so I can’t test that. The cables were bought from BHphoto and not some cheapo brand.
By the way I called Canon tech support twice on this issue. Both times I was put on hold while support checked with some higher-level tech guy. The first time I was told that these cams don’t work with FW800. The second time I was told they just tried it and it works fine so it must be something on my end. That left the batch of cables I have.
I’m not following your solution: You have recorded HDV media on camera. You attach the camera to Mac and are in the capture/import window of FCP X, you put the camera in record mode and record some footage? Then switch to play mode and rewind to the beginning of your HDV footage and then FCP X recognizes the camera???
MacPro4,1 2.66GHz 8 core 12gigs of ram. GPU: Nvidia Geoforce GT120 with Vram 512. OS X 10.6.x; Camcorders: Panasonic AG-HPX170, Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
