Activity Forums DaVinci Resolve import *.exr with correct LUT and settings?
  • import *.exr with correct LUT and settings?
    Posted by Felix Gorbach on August 27, 2012 at 12:43 pm
    Hy folks,
    posted this some weeks ago and couldn´t get an answer on this issue. I made some r&d and want to inform you about what I found out and what kind of works – and maybe there is some better way.
    The “challenge”:
    Have a open exr sequence renderd from Nuke in linear workflow. When I load the sequence into after effects, it looks the same as in Nuke. When I load the sequence into speedgrade its far too dark (like in Resolve), but when I apply a Gamma 2.2iLut – it works fine and looks exactly like in Nuke.
    Some try of solotioin:
    This would save may day – I thought, and copied the iLut from Speedgrade to the LUT folder of resolve. (I gave myself the fun and copied all of them…)
    Some of the new LUTS are working fine in Resolve, some not – and guess what – the Gamma 2.2iLut doesn´t show up in Resolve. So far so “good”. The Lut Files that are working are in filesize about 90k and bigger, the Gamma 2.2iLut is 1k – so I checked the files in notepad.
    In the working 90k files there are thousands of numbers. I guess some values to calculate for Resolve.
    In the Gamma 2.2iLut from Speedgrade it says:
    SourceGamma = 1.0; //Gamma of the source material
    TargetGamma = 2.2; //Gamma of the display device
    out = pow(in, SourceGamma / TargetGamma); //common value for all output channels
    red = out;
    green = out;
    blue = out;
    So I interpreted that I just have to lift the gamma in the primaries to 0.22 And yes – it starts to look like the correct image, but its to saturated and the shadows are too bright. – Just a tick, but it´s not the correct interpretation.
    I gave myself a try with Color scinece – with DaVinci ACES it´s nearly OK – With DaVinci YRGB it´s totally desaturated and does not look like it should.
    So these are my experiences about open exr so far. Does anybody now a Gamma 2.2iLut that works in Davinci? Maybe this would help, like in speedgrade. Has anybody a solution for this issue in general? How can it be that after effects interprets the open exr out of the box correctly and that this industry standard “open exr” is so poorly supported by the new version of DaVinci?
    Sorry for this bad question, but during my r&d process I got a bit frustrated.
    thanks for your help,
    Felix
    Marc Wielage replied 7 years, 11 months ago 4 Members · 3 Replies
  • Ingi Fiev
    October 20, 2018 at 4:26 pm
    Hello Felix,
    It’s been 6 years since your post, have you found a solution to this problem?
    I also am very fustrated with resolve not being able to import EXR in linear color space, it doesn’t make any sense… And the EXRs you export from DaVinci also seem to have a gamma 2.2 on them…
  • Tero Ahlfors
    October 21, 2018 at 8:15 am
    I didn’t know this was a problem in the first place. One can use the VFX LUTs, one can use the color transform effect or one can use the Resolve color management to set the input and output of the clips to a needed gamut/gamma.
    Resolve won’t automatically export EXRs in linear so one would need to use the same tools to turn the export to linear. A timeline correction for everything or use color management.
    The manual is a good place to start.
  • Marc Wielage
    October 21, 2018 at 10:18 pm
    There is a way to handle EXR Linear files with the Color Space Transform OFX plug-ins in Resolve 15.
    The first node would be a CST node set to Input Gamma Linear, and Output Gamma 2.4. The second CST node would be set to whatever color space processing you want to use and wind up with. Experimentation should give you correct results.
    (And my thanks to Juan Salvo for coming up with this idea.)
