Activity Forums Adobe Premiere Pro Import Error – windows
  • Import Error – windows
    Posted by Chris Tompkins on September 8, 2010 at 12:03 pm
    I shoot DVCPRO HD and edit in FCP.
    We have a client that needs to also provide finished video clips to some folks in Germany.
    We have been going back and forth trying to workout a format that I can provide to them that they can import into Adobe Premiere on Windows.
    They sent me a clip that works for them-
    1280 X 720
    30 fps
    apple photo – jpeg millions of colors
    16bit big indian mono 16.kHz
    So I replicate this and send them a file.
    The only dif is the audio setting is slightly different:
    They get an error and cannot import. Here is the windows generic error:
    Anyone have a suggestion?
    Thank You so Much.
    Chris Tompkins
    Video Atlanta
    Dexter Andrada replied 15 years, 11 months ago 2 Members · 4 Replies
  • Dexter Andrada
    September 8, 2010 at 3:35 pm
    Maybe it has something to do with the PAL/NTSC Setting?
    Did you guys agree on the proper setting for this as well?
  • Chris Tompkins
    September 8, 2010 at 4:19 pm
    Ya, I started out making PAL clips and they went with 30fps.
    I guess I could try a PAL conversion but w/ 30 FPS instead of 25?
    Thanks.
    Chris Tompkins
    Video Atlanta
  • Chris Tompkins
    September 8, 2010 at 4:39 pm
    Ya, Can’t seem to make a PAL HD clip w/ Compressor. I have some converts to PAL DV or DV50 but not DVCPRO HD PAL.
    Chris Tompkins
    Video Atlanta
  • Dexter Andrada
    September 8, 2010 at 6:05 pm
    You can use AE to make the conversion to NTSC HD to PAL HD. Maybe other cna chime on on the proper settings.
    good luck
