Activity Forums DaVinci Resolve Import edl with r3d clips
  • Import edl with r3d clips
    Posted by Ben Dittrich on June 17, 2011 at 10:16 pm
    Hey Guys,
    i’am did some tests on an upcoming Project and got problems importing an edl.
    The edl comes from an Avid system and relates to some r3d clips.
    They are fine in the Media Pool, In the Browse Menue and in the Master Session, i can shuttle threw the clips without any Problem.
    But as soon as i Load a edl and want to conform, the clips got a Red Cross in
    Ben Dittrich replied 15 years, 3 months ago 3 Members · 4 Replies
  • Robbie Carman
    June 17, 2011 at 11:46 pm
    check out the EDL are the REEL/File names for the RED files truncated?
    Robbie Carman
    Colorist and Author
    Check out my new Books:
    Video Made on a Mac
    Apple Pro Training Series DVDSP
    From Still To Motion
    Twitter
    Blog
  • Ben Dittrich
    June 18, 2011 at 6:01 pm
    I checked everything, the edl is fine and the names are all correct.
    Even when i change them manualy for the file and in the edl it will not work.
    I realy don’t get it….
    How do you guys import Red Material? Whats your Workflow, also with edls, or?
    Benjamin Dittrich
    Digital Artist
    C.3 Frankfurt
    SilverSurfer79@gmx.net
  • Vladimir Kucherov
    June 18, 2011 at 8:01 pm
    Do you mind posting a few lines from the EDL? Keen eyes might spot problems easier that way
  • Ben Dittrich
    June 19, 2011 at 11:11 am
    Hey Everybody.
    Solved the Problem.
    There was 2 Seetings which didn’t match the edl
    In Config Menue and then under the source Tab:
    Make sure for: Master Red Decoder Settings that your timecode is set to the correct timecode your edl is edited with.
    Check in the Browser if the start tc matches the edl tc
    My default seeting was “Camera” the correct one for my purpose is “Absolute”
    But this doesn’t help when the system is looking at the wrong reel names, like in my case.
    So i changed in the Config Menue the Timeline conform options:
    Use timecode: Embedded in the source clip
    And then:
    Assist using reel numbers from the… i switched to: Embedding in the source clip file.
    After that everything matched the Informations which came along from the Avid edl
    Thanks everybody for help & I hope that helps if somebody has a similar problem.
    Greetz
