Activity › Forums › Adobe Premiere Pro › import DV AVI file into PPro CC
Posted by Brett Nelson on November 20, 2013 at 1:39 amHi,
I’ve looked all over for this answer, but come up empty. How can I import video clips that were captured as AVIs on a PC coming originally from miniDV tape into PPro CC on OSX? I am able to do this with CS6. I am also able to import in PPro CC on one of my MacBook. However, on my MacPro machine with the same project and same media, I get an import error. There must be some little app I have installed on the one machine which is not on the other. I’ve tried VLC and DivX among others. BTW I can’t import these DV codec AVIs in PS or AE CC either.Any suggestions?
thanks!
Brett
Young Monica replied 12 years ago 5 Members · 9 Replies -
Tero Ahlfors
November 20, 2013 at 7:47 amTry setting the file permissions for the footage. You might get an import error if the OS doesn’t have permission to use the file.
Brett Nelson
November 20, 2013 at 3:56 pmI don’t think it’s a permissions issue. The files work without any trouble in PPro CS6 and QT on the same system. The same files also work without any trouble in PPro CC on my other system. The question is what driver do I need to have installed to have CC import/read a DV-codec AVI. It doesn’t seem like this should be this hard, especially for an app that’s cross-platform.
thanks,
Brett
BTW, funny exchange with one of the Adobe tech support people. He saw it was DV-codec AVI and he asked what camera I used to shoot it with. I said I had no idea, that the footage was 10 years old. He said, “You don’t know what camera? It’s ten years old?!” I guess his parents didn’t have a miniDV camcorder around the house when he was in grade school.
Brett Nelson
November 20, 2013 at 4:34 pmI just converted my DV-AVI in Squeeze to a DV .dv file. Still no go.
Brett
Tero Ahlfors
November 20, 2013 at 4:43 pm[Brett Nelson] “I don’t think it’s a permissions issue. “
Well can you even try to set the permissions? Even if you don’t think it’s the issue.
Brett Nelson
November 20, 2013 at 4:59 pmTero,
Yes. I did try, but that did not solve it. I decided to take what should have been the obvious option, I transcoded. I used MPEG Streamclip and made DV QTs. I resisted doing this because it’s hours of footage, but it works. Also, I’m now suspecting that these are not mere mortal DV-AVIs. I am remembering that they were created 3 years ago by someone using Premiere Elements. They well may have had some strangeness wrapped in them that for some reason was viewable by other programs but not CC on this system.Thanks for the input.
Brett
Steve Brame
November 20, 2013 at 5:43 pmYou could use MediaInfo to confirm your suspicions.
https://mediaarea.net/en/MediaInfo
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
“98% of all computer issues can be solved by simply pressing ‘F1’.”
Steve Brame
creative illusions Productions -
Brett Nelson
November 20, 2013 at 6:22 pmSteve,
I checked the clip with Mediainfo and nothing jumps out as unusual. It’s Sony DV codec, 720x480i, YUV. I just tried a JPEG AVI created from a still camera. That does not import either. Maybe my DV AVIs aren’t the problem after all.
I must have an app on the MacBook that reads AVIs which CC is using. I’ve tried to isolate which it might be. QT 7, MPEG Streamclip, VLC, DivX, Squeeze are all current versions on both systems. Again, I don’t have trouble viewing these AVIs with any program other than the ones in the CC suite.Brett
Mike Cohen
November 22, 2013 at 10:17 pmInteresting issue to me, since we are about to go to CC and have terabytes of DV-AVI from Windows (captured from analog tape via Premiere 6.5 before our analog machines died).
Though we mostly use Windows, we do have some Macs.
Walter – any thoughts?
Mike Cohen
Young Monica
September 10, 2014 at 6:01 amThis often happens with AVI files that were created by digital still cameras or software that doesn’t correctly support the AVI standard. Plus, sometimes it doesn’t show video, only the audio with. Here is a possible solution for you: Transcode the AVI File to MPEG-2.
https://jacknjchn.tumblr.com/post/56121345839/how-to-open-and-edit-avi-files-in-adobe-premiere-pro
