Activity Forums Adobe After Effects Expressions Import comps from external project
  • Import comps from external project
    Posted by Sebastian Gomez on July 23, 2020 at 4:46 pm
    Hi folks, here’s the situation:
    What I have: A .jsx that selects and adds comps from the project to the active comp based on parameters defined by the user in a dialog prompt.
    What I need: A .js script that does this but calls and adds the comps from an external AE project, so as to keep the working project clean and light weight.
    Questions: The import object in the AE scripting guide does not seem to cover this. Is it possible to do it with a .js, or this would require C/C++ with the SDK?
    UPDATE:
    I found some clues in this post. I could import the whole project, and search and add specific comps , but I’d need to delete unused items after.
    Any help or clues will be much appreciated.
    Chaz Chester replied 6 years, 1 month ago 2 Members · 1 Reply
  • Chaz Chester
    July 26, 2020 at 2:39 pm
    It should be possible to do this with a script. It’s a little over my head, but I think you could have the script open the external project, reduce the project to the intended comps, save a copy with the menu command, open the destination project, import the copied aep, and then delete the copied aep so it isn’t taking up space on your computer. It’s a cool idea, so I hope someone who knows more than I do helps you out.
