Activity › Forums › Adobe After Effects › Import Compositions with Media Browser
  • Walter Soyka
    February 6, 2023 at 9:18 pm
    You can’t use the Media Browser to import After Effects compositions when you’re in Ae. (You CAN use the Media Browser to import After Effects compositions when you’re in Premiere, though!)
    Instead, use File > Import and select your AEP file. Ae will import the entire project file you selected into your current project.
    If you only wish to import a specific comp from a project, you might want to reduce the project first.
