Activity Forums Adobe After Effects Import comp into new project?
  • Import comp into new project?
    Posted by Shirak Agresta on March 13, 2008 at 7:21 am
    Is there a way to import just a single composition from one project into another, without having to import the entire After Effects project that contains the comp you want to use?
    I wish you could import it like a photoshop file layer, where you could scroll through and pick the comp you want to import and everything associated with that comp would import with it.
    Doesn’t this make sense to be able to do (and easily)?
    Julius Caesar and the Roman Empire couldn’t conquer the blue sky.
    Gary Glover replied 13 years, 7 months ago 4 Members · 4 Replies
  • John Dickinson
    March 13, 2008 at 11:13 am
    1. Open the project that has the comp you need.
    2. In the Project Panel Select only the comp(s) you want to keep.
    3. From the main menu choose File > Collect Files.
    4. Select the “For Selected Comps” option.
    5. Select the “Reduce Project” option.
    6. Click the “Collect” button.
    7. Give the folder a name.
    8. Open your main project and import the project you just collected (which contains only the comp you need.
    JD
    John Dickinson
    Motionworks
    Making it Look Great 1
    Design and Production Techniques for
    Adobe After Effects and Zaxwerks ProAnimator
    Available Now
  • Ian Corey
    March 13, 2008 at 1:58 pm
    I’ve thought that too. But in the long run I’ve never been sorry that I imported the entire project. It’s just one more folder and– who knows?– you might find something else you needed in that project!
  • Shirak Agresta
    March 13, 2008 at 6:10 pm
    Great, thanks! I’m assuming, then, that this won’t affect the original project that you’re collecting files from? As long as you don’t save it or something like that?
    Thanks again.
  • Gary Glover
    January 24, 2013 at 4:04 pm
    Thanks, John. I have been trying to find this answer for a week.
    Be blessed,
    Gary
