Activity Forums Storage & Archiving Import BRU PE Catalog
  • Ian w. Arsenault
    October 11, 2011 at 3:06 pm
    Andrew,
    Which version of Bru PE are you using?
    The BRUSetta Import Tool does this.
    (included on the BRUSetta Stone CD at least as of v2.2.0 build 403)
  • Andrew Saliga
    October 11, 2011 at 8:57 pm
    I’m using 2.2.0. I only had about 20 tapes, so I used the tape import tool. Do you know if there is a new version coming out? I seem to have frequent problems with the search function.
    Andrew Saliga
    I/O Specialist/Assistant Editor
    Steelehouse Productions
    http://www.steelehouse.com
