Activity Forums Adobe Premiere Pro Import as dual mono
  • Import as dual mono
    Posted by Matt Scholes on June 26, 2017 at 9:37 pm
    I know how to change a one track stereo clip to dual mono in PP, but I have literally hundreds of clips that I want to look through, so I want to import them as dual mono, not stereo and don’t have to go through changing every one separately.
    Any ideas?
    If you aren’t willing to change you shouldn’t be editing” – Richard Marks
    Jeff Pulera replied 6 years, 10 months ago 5 Members · 5 Replies
  • John Pale
    June 27, 2017 at 12:36 am
    Just change your preference setting to mono before importing. It’s under Media, I believe.
  • Mark Whittle
    June 28, 2017 at 9:25 am
    Hi Matt,
    In my case my main camera has cam mic on L channel and Radio mic on R. Quite a lot of the time the radio isn’t in use so this track is mute. By default it imports as a .mov with a single stereo file.
    What I do is select all the files I want to import in the media browser, import into one bin, then select them all, right click and choose Modify > audio channels.
    It changes clip channel format to Mono, Number of Audio clips: 2.
    If I’ve done a shoot with only one track I can just uncheck the Clip 2 R selection and only have one track.
    I often shoot with multiple cameras so I like to choose the settings manually depending on the camera. You can save a preset for each camera if you want to make settings quicker.
    Hope that helps.
    Mark W.
  • Matt Scholes
    June 28, 2017 at 1:31 pm
    Ok, that makes sense.
  • Onel Mulet
    October 30, 2019 at 1:48 pm
    Avoid getting stereo file imports by going to Preferences/Timeline and in Default Audio Tracks, select mono for all the different audio paths. I often had this problem importing audio into premiere since I am insistent on having mono dialogue tracks, and I was tired of using the work arounds. This is part of my regular workflow and it removes the extra steps involved in converting stereo to mono.
  • Jeff Pulera
    October 31, 2019 at 1:55 pm
    Hi Mark,
    When you have all the clips imported into Project Bin, multi-select all of them at once, then right-click and go into Modify > Interpret > Audio and you should be able to change them all together in one shot.
    Depending on your needs, you might also just use Fill Left or Fill Right in the timeline. Say I have a shotgun mic and a wireless mic on camera, on L and R channels, for a wedding ceremony. I’ll only need the R channel briefly for the vows, using the shotgun the rest of the time. I can apply Fill Right With Left effect for most clips (again, using multi-select) and then use Fill Left With Right just for the vows clip. Thereby retaining the stereo settings throughout production and both channels are filled when exporting stereo.
    Jeff Pulera
    Safe Harbor Computers
