Import .ARW photo in Sony Vegas
Posted by Nino Pericoli on December 19, 2016 at 11:29 amHi!I need a trick or plugin to import my .ARW photo in sony vegas 13.I’m speedy to masking and edit compared to photoshop.Unfortunately vegas seem to work jpg only.Someone has solutions?
Marco Baer replied 9 years, 8 months ago 5 Members · 13 Replies -
Graham Bernard
December 19, 2016 at 11:35 am[Nino Pericoli] “I need a trick or plugin to import my .ARW photo in sony vegas 13”
What’s that format? I haven’t heard of an ARW Photo.
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Ole Kristiansen
December 19, 2016 at 11:47 amI think the .arw is from a Sony Nex camera !
Vegas pro work well with .png !
Graham Bernard
December 19, 2016 at 12:11 pmWill Vegas import those files then?
* Grazie
Nino Pericoli
December 19, 2016 at 12:34 pmYes,from Sony Camera(a6300).If i convert to png i loose the benefit of a raw format edit,probably…
Aaron Star
December 19, 2016 at 3:00 pmYou could convert your raw format to EXR. That format will hold all of your raw information, given your conversion software does not clip your info in the processing.
You could also convert to Photoshop format, as vegas works well with Photoshop files very well.
Nino Pericoli
December 19, 2016 at 7:35 pmThanks Aaron. Which is the best converter i can use to transform? Is better exr or photoshop format?
Marco Baer
December 19, 2016 at 9:53 pmYou could also install the Microsoft Camera Codec Pack which installs various RAW codec and which should enable you to import and edit .ARW files natively in Vegas Pro.
Nino Pericoli
December 19, 2016 at 10:13 pmMeantime i’ve tried Reaconverter 7 and wow!Works very well!I can transform .arw files in all formats (psd included)!
