Activity Forums Adobe After Effects Import and Replace Usuage
  • Import and Replace Usuage
    Posted by Martin Stacey on October 27, 2016 at 3:58 pm
    Can anyone tell me if it’s possible to do this before the following item in the render queue starts rendering.
    I have this setup. Comp 1, which is my main comp. Then Comp 2 which contains Comp 1 but also has a guide layer over the top.
    So the workflow I would like to happen is:
    Render Comp 1
    Import and Replace Usage Comp 1 in Comp 2
    Render Comp 2
    But at the moment, it doesn’t seem to do the replace until the render queue has finished rendering both comps, which is obviously not that helpful, but I may be missing something.
    Martin Stacey replied 9 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
