Activity › Forums › Apple Final Cut Pro Legacy › Import and edit divx movies from divx camera
  • Rafael Amador
    January 24, 2009 at 2:41 am
    Hi Sabbie,
    Your codec is 8b YUV, so 8b Uncompress is the codec that will keep the whole information of your divx file. Yes big file.
    Try Proress too.
    Rafael
    http://www.nagavideo.com
  • Habi S.
    January 24, 2009 at 11:08 am
    ProRes works just fine, thank you!
  • Chris King
    June 23, 2014 at 9:15 am
    You may get some DivX files and need to add these DivX files to Final Cut Pro for editing on Mac. However, when you’re trying to import the DivX video, you only to find that the files are not supported by Final Cut Pro(even the latest FCP X). Here you are recommended to convert DivX to ProRes, which are highly compatible with Final Cut Pro.
Page 2 of 2
