Activity Forums Apple Final Cut Pro Legacy Import Anamorphic
  • Import Anamorphic
    Posted by Andy Lancaster on January 4, 2009 at 4:47 pm
    I am importing footage files that are DVCPRO HD 720p60 960×720
    When they are imported anamorphic is checked in the browser and they look stretched out. Is ther a way to set them to import without being anamorphic?
    Louis Germano replied 17 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    January 4, 2009 at 4:49 pm
    Nope. DVCPRO HD is an anamporphic format…it will onl come in anamorphic. Are you sure your sequence settings match the clip settings? Did you choose the proper Easy Setup then make a new sequence?
    Shane
  • Andy Lancaster
    January 4, 2009 at 8:49 pm
    The clips have already been captured to a drive. I am importing them as files. When I do, anamorphic is checked for the clip when I import it, but it looks stretched out in FCP. If I uncheck it, it looks correct. I made the sequence not anamorphic because I dont want to look at my shots stretched.
  • Thompson Coles
    January 5, 2009 at 12:29 am
    you will not want anamorphic checked on an HD project. your project video is already 16:9. unlike an SD project you only have 540×468 and we apply anamorphic to it to make it 16:9. the reason it was anamorphic was a result of a miss checked box in you capture preset..
    I hope this helps. Sorry for any mistakes i wrote this on my phone
    thompson
  • Sean Oneil
    January 5, 2009 at 4:21 am
    As Thomson says, the Anamorphic flag is for standard def only. If your footage is not coming in right, check is the pixel aspect in the FCP Browser.
    Sean
  • Louis Germano
    January 6, 2009 at 3:25 pm
    maybe you should walk down the hall and get Daiva to turn off the “anamorphic” button on the Dalet…it’s all her fault!!
    LG 22
  • Andy Lancaster
    January 6, 2009 at 4:16 pm
    I dont speak French
  • Louis Germano
    January 6, 2009 at 4:25 pm
    looks like you’re screwed then
    LG 22
