Activity Forums Adobe After Effects Import an Illustrator path?
  • Import an Illustrator path?
    Posted by Nathan Quattrini on March 9, 2007 at 8:21 pm
    Is there a way to import the path and then use it to thus make the object? I have a path in an Illustrator file that need to be made to glow…making it look like a neon sign. Can I import the path in? Or do I need to stroke the path first in Ill and then import to AE? thanks
    Kevin Camp replied 19 years, 5 months ago 2 Members · 1 Reply
  • Kevin Camp
    March 9, 2007 at 8:47 pm
    in my experience your ai file will import as it looks in ai. so if you see your path as black 1 pt line, when you import into ae, it will look like a black 1 pt line and you can effect it from that point.
    you can also cut & paste vector data from ai in to ae, the vector will be pasted as a mask on a solid. you then could use stroke to create line thickness and color, then glow over the top of that.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
