Activity Forums Avid Media Composer import adobe premiere captured shot to avid Xpress
  • import adobe premiere captured shot to avid Xpress
    Posted by Alex_tremblay on August 8, 2005 at 12:01 pm
    HI
    I have a little problem with my workstation ( a PC running on winXP ) : my firewire card is not supported by Avid Xpress, but on this same PC, i have a good working version of adobe premiere wich can capture from my VX2000 with no problem. What i had thought to do right now is to capture my footage with premiere, than import them in avid Xpress
    The thing i was wondering is: does the two software uses the same codecs, and it makes no diffrence if i capture it from premiere, or i am missing some more quality possible than if i buy right now a compatible firewire card….
    I am a bit short on money right now, that is why i want to proceed with premiere on the capture, untill i get few dollars on the side.
    Thanks for your advice
    alex
    Digitalcutter replied 21 years, 1 month ago 3 Members · 3 Replies
  • Rj Hewitt
    August 8, 2005 at 9:46 pm
    Premier captures to AVI files where as the Avid system captures to OMFI files. The Avid system is however able to import these AVI files unless they were captured through a Matrox card using the Matrox codec.
    However I’ve yet to come across a Firewire card that didn’t work with the Avid applications (although I know others have). Have you tried setting the Capture settings for a ‘GenericDVDevice’? Each machine setting differs slightly but most should respond reasonably well to this setting. You may find the full list of supported cameras on Avid’s Website.
  • Alex_tremblay
    August 8, 2005 at 10:05 pm
    R Hewitt ,
    thank you for your answer
    My capture card is a pinnacle studio DV (old thing, i know 🙂 )
    [R Hewitt] “You may find the full list of supported cameras on Avid’s Website.”
    I’m 100% sure the problem is not the camera, it’s working well on a friend’s xpress setup
    The real problem is the firewire card…. it seems to be getting some signal, but then i loose it…. like if the cam was turning on and off every 15 sec…
    [R Hewitt] “The Avid system is however able to import these AVI files unless they were captured through a Matrox card using the Matrox codec.”
    Do you think the avi file with the DV-NTSC codec will provide the same image quality than the omfi from avid?
    And i won’t have to render it before working with?
  • Digitalcutter
    August 10, 2005 at 10:49 am
    No u wont have to render the imported files coz while they are getting imported they are converted as OMFI and from that time onwards they are a part of Avid OMFI Mediafiles.
    Yeah the DV-NTSC or PAL codec are the same as they are captured on a camera..there will be no deterioration of image quality.And if they are in such codec it wont take much time to import too…..where as some AVI’s wud take some time…..soo u may import any DV STREAM justlike that into avid…………..
    And U can buy a cheaper Firewire card with a Via Chipset on it…i dnt think it wud cost u much ……..
    Regards.
