Activity Forums Adobe After Effects Expressions Import Adobe Illustrator .ai file and place it on a active comp as a layer with Extendscript
  • Import Adobe Illustrator .ai file and place it on a active comp as a layer with Extendscript
    Posted by Dennis Van zwet on September 5, 2019 at 7:51 am
    Hi all,
    I have a problem getting started with a script that allow me to import a illustrator file (with dialog import window, command-i), place it on the active composition as a new layer, convert it to a shapelayer, add layer style (stroke, stroke color, stroke size, stroke position) and add trim path keyframes.
    This is my starting code:
    var myComp = app.project.activeItem; //active comp
    var myFile = app.project.importFileWithDialog(); //import illustrator file
    var myLayer = myComp.layers.add(myFile); //add to active comp as new layer
    I get a error “After Effects error: Unable to call “add” because of parameter 1. Array is not of the correct type.”
    Hope someone can get me started, what am I doing wrong?
    Greetz,
    Dennis.
    Dan Ebberts replied 6 years, 12 months ago 3 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    September 5, 2019 at 1:30 pm
    You’re close. importFileWithDialog() returns an array of items. Try changing the last line to:
    var myLayer = myComp.layers.add(myFile[0]);
    Dan
  • Dennis Van zwet
    September 5, 2019 at 2:41 pm
    Yeahhhh, that worked, thank you Dan.
    I think I’m starting to like learning Extendscript.
  • Dennis Van zwet
    September 5, 2019 at 7:02 pm
    Sorry for bothering you guys again, I have looked at al possible threads, but found noting.
    I’m having a problem with creating a shape layer from an .ai file.
    On a selected .ai layer I’m using:
    app.executeCommand(3973);
    But nothing happens, is this is the correct way to “Create Shapes from Vector Layer”?
    var myComp = app.project.item(1); //active comp
    var myLayer = myComp.layers.add(myFile[0]); //add to active comp as new layer
    myComp.layer(1).selected = true;
    //alert( app.findMenuCommandId("Create Shapes from Vector Layer"));
  • Rainier Raydán
    September 5, 2019 at 8:49 pm
    Hi!
    Try this
    myLayer.selected = true;
  • Dennis Van zwet
    September 6, 2019 at 6:00 am
    Hi Rainier,
    Thank you for your reply. Tried your code, the layer in my comp is selected but converting to a shape layer doesn’t work, I’m not sure why?
    Greetz.
  • Dan Ebberts
    September 6, 2019 at 3:01 pm
    Try it this way:
    myComp.openInViewer();
    app.executeCommand(app.findMenuCommandId(“Create Shapes from Vector Layer”));
    Dan
  • Dennis Van zwet
    September 6, 2019 at 3:21 pm
    Thank you ones again Dan, my new hero.
    As I understand the comp was not active in the viewer?
    https://docs.aenhancers.com/items/footageitem/#footageitem-openinviewer
  • Dan Ebberts
    September 6, 2019 at 3:31 pm
    My guess is that importing the file takes focus away from the comp panel and gives it to the project panel.
    Dan
