Activity Forums Apple Final Cut Pro Legacy import ACVHD
  • Posted by Adriano Castaldini on March 21, 2010 at 12:54 am
    I have a ACVHD handycam and when I import the streams into Finalcut, the .mts files transcode into ProRes 422. Could this transcoding get worse the quality of the mts files? I read that Premiere CS4 import native mts files. Does this mean that Premiere doesn’t change the files quality? or simply means that Premiere transcodes on-the-fly? This question is based on the fact that I read that mts file “have to” be converted because ACVHD is not a frame-based codec. Is it true?
    Dennis Radeke replied 16 years, 5 months ago 4 Members · 6 Replies
  • Tom Wolsky
    March 21, 2010 at 1:28 am
    Yes. What this means is that Premiere works with the native crappy MPEG-4 H.264 media that’s horrible to edit or composite or do anything will, while FCP converts the media to a high resolution codec that can be used for any effects and edits and responds easily.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Adriano Castaldini
    March 21, 2010 at 12:51 pm
    Thanks Tom!
    So, if you had to choose between mts-in-CS4 or prores422-in-FCP, you’d choose FCP (even if preres422 is an “added step”), right? So in your opinion the FCP “re-encoding” (into prores) doesn’t get worse the quality of mts, right?
    Infact… I have the last question: using FCP7 with intel-mac, I see that the encoding from mts to prores is very fast! So, perhaps FCP7 doesn’t really “encode”…perhaps it simply re-pack the video file (without changing the video quality with an encoding step)?
    Thanks.
  • Tom Wolsky
    March 21, 2010 at 2:28 pm
    Yes. No. It transcodes it to a different codec and format both video and audio. Speed depends on the speed of your computer.
    All the best,
    Tom
    March 21, 2010 at 4:40 pm
    Thanks a lot, Tom!
  • John Fishback
    March 21, 2010 at 7:02 pm
    ClipWrap may be another option.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Dennis Radeke
    March 30, 2010 at 11:10 am
    As with anything there are trade offs.
    Premiere Pro offers native editing with the idea that touching your pixels is always a bad thing. It’s also faster since you can edit your media immediately as opposed to waiting for a transcode. For codecs such as Panasonic’s P2, there are no downsides. Since AVCHD is a temporally based codec, as Tom pointed out, editing on a less than amazing system may show a sluggishness in scrubbing and editing that you really don’t want now.
    Transcoding or rewrapping is generally good for something like AVCHD, H.264, or other temporally based codecs. Pixel loss is negligible if at all and the resulting editing experience is more in line with what you expect. The only downside is that it takes time to accomplish this. With non-temporal codecs, this is a waste of time but necessary if your NLE doesn’t understand the codec.
    Bottom line – it’s always your choice and both approaches have merit.
    For the future, Premiere Pro will have some enhancements that will make editing temporal codecs as easy as any other. The link below will point you to it.
    Enjoy,
    Dennis
    https://blogs.adobe.com/genesisproject/2009/11/technology_sneek_peek_adobe_me.html
