Activity Forums Maxon Cinema 4D Import a C4D project in a new project.
  • Import a C4D project in a new project.
    Posted by Maxim Fischer on June 1, 2018 at 10:22 pm
    Hello,
    Here is my problem. After I imported a C4D project file into a new one there are always the textures in the material missing.
    Therefor I manualy copying the textures into the “tex” folder. Is there a faster way?
    Maxim Fischer replied 8 years, 3 months ago 2 Members · 2 Replies
  • Steve Bentley
    June 1, 2018 at 11:09 pm
    You can have multiple valid tex folders (you can find the list in your prefs) as long as the textures from one project are in a valid tex folder, then when you import a c4d file into a new one all should be good.
    C4D normally asks you if you want to copy the image you are applying to a material into one of the tex folders. If you say no, it’s somewhere on your drive and will get used for that project only – it can get “lost” when you open the project again. So its a good idea to set those tex folders up and say yes when C4d asks where you want to put it.
    If all of that has been done, I’ve found when an image goes missing, if I go find it for one texture, save the file as something else and then open the file back up, C4d will often find the others. Its like that missing image give c4d a hint as to where to look.
  • Maxim Fischer
    June 1, 2018 at 11:25 pm
    Thank you for the reply.
    I always applying Cinema 4D to save the images in the “tex” folder.
    At the time I ‘m using only Octane Shaders. Maybe its a problem with Octane itself.
