Activity Forums Apple Final Cut Pro Legacy Import 720p24 clips from hard drive copied from firestore
  • Import 720p24 clips from hard drive copied from firestore
    Posted by Daryl K davis on June 6, 2006 at 3:38 am
    I just received a firewire drive with files that were copied from footage shot and captured onto a firestore drive. It appears they simply copied the files over and sent to me for editing.
    When I go to import P2 and select (+) the firewire drive and I can see the various folders of clips from the different days they shot. I am wondering just what am I supposed to import.
    Within the folder there are the following folders:
    AUDIO, CLIP, ICON, PROXY, VIDEO, VOICE
    So far nothing seems to be importing as I keep getting the message: Selected path does not contain a P2 volume.
    Could there have been an error in how they copied the files over?
    Is there a specific way I should be doing this?
    Thanks so much.
    Daryl Davis
    DK Davis / Editor/ Post Super
    Daryl K davis replied 19 years, 11 months ago 2 Members · 3 Replies
  • Shane Ross
    June 6, 2006 at 5:01 am
    Name that folder CONTENTS and you should be good to go. Try it and see. That worked for another fellow not to long ago.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Daryl K davis
    June 6, 2006 at 6:12 am
    Could it be a problem that this firewire drive is formatted with MS-DOS File System?
  • Daryl K davis
    June 6, 2006 at 6:17 am
    Got it. Yes the folders have to be named CONTENTS. I just renamed them and all is well.
    Thanks Shane
