Activity › Forums › Maxon Cinema 4D › Import .3ds file into C4d 11.5
  • Import .3ds file into C4d 11.5
    Posted by Brian Mills on March 19, 2010 at 8:24 pm
    I have a .3ds file i got from a free site…when i try sand open it in C4D I keep getting an error that it cant open in the image viewer…i am very novice at C4D am I missing something here?
    Dan Nuckolls replied 14 years, 10 months ago 3 Members · 2 Replies
  • Randy Johnson
    March 20, 2010 at 8:44 am
    1.Open C4D
    2. File: Merge
    3. Select 3ds file.
    /randy
  • Dan Nuckolls
    November 14, 2011 at 4:17 pm
    I’ve recently run into this same issue and found this post on the CCow forums.
    What you mentioned does not work for me.
    I put the 3DS Exchange plugins in the plugin folder. (root level of that folder)
    Is there something else I need to do?
    Dan Nuckolls
    MoGraph/Editor Guy
