Activity Forums Adobe After Effects Implementing random seed but maintaining several objects playing at the same time not just 1
  • Implementing random seed but maintaining several objects playing at the same time not just 1
    Posted by Wyclef Chron on December 10, 2012 at 8:25 pm
    Hey, wanting to use this code to make a composition of a star randomly appear on stage but it only works for 1 at a time. Wondering how I can tweak this to allow for 3, and at varying times not in sync. I could just have 3 different layers and change the holdTime but thought there might be a more logical approach. New to expressions.
    holdTime = 2; //time to hold each position (seconds)
    minVal = [0.2*thisComp.width, 0.2*thisComp.height];
    maxVal = [0.4*thisComp.width, 0.8*thisComp.height];
    seed = Math.floor(time/holdTime);
    seedRandom(seed,true);
    random(minVal,maxVal)
    Appreciate any help. Thanks.
    Darby Edelen replied 13 years, 9 months ago 2 Members · 3 Replies
  • Darby Edelen
    December 11, 2012 at 4:54 am
    I believe you can just modify your seed slightly based on the layer index, something like:
    seed = Math.floor(time/holdTime) + index;
    Darby Edelen
  • Wyclef Chron
    December 12, 2012 at 10:17 pm
    hmmm… that didn’t seem to work.
  • Darby Edelen
    December 12, 2012 at 11:05 pm
    [wyclef chron] “hmmm… that didn’t seem to work.”
    Sorry, it seems I didn’t quite understand the problem. I’m still not quite sure the behavior you’d like to see but this should be closer:
    seedRandom(index, true);
    offset = random(0, 1);
    holdTime = 2;
    seed = Math.floor((time + offset)/holdTime);
    Each layer will still hold for 2 seconds but the updates of the random values will be offset by up to 1 second from one another.
    Alternatively you can just generate a random number for the holdTime per layer:
    holdTime = random(1, 3);
    Some layers will update more frequently than others with this method.
    Darby Edelen
