Activity Forums Adobe After Effects Imaginary Title Sequence
  • Imaginary Title Sequence
    Posted by Eyad Abutaha on June 17, 2008 at 4:36 am
    As you guys mentioned that my clips were short and asked me to make longer clips; here is a “30 Sec” title sequence; based on tips from this forum tutorial page also Andrew Kramer “3D Room” “Smoke Screen” tutorials.
    I had problems with the Audio; I posted last week; got your advices to make it .wav format, but still a little bit the Audio is off; or not following the motion.
    Any ways, your opinions are always welcomed.
    https://www.eyadstudio.com/Media/prison_cel/prison_cel.html
    Eyad
    Eyad Abutaha replied 18 years, 2 months ago 5 Members · 5 Replies
  • Tl Westgate
    June 17, 2008 at 11:57 am
    Settle down on the jerkiness. It’s too irritating. Smoother and subtler are the ways to go.
    — TL
  • Erik Pontius
    June 17, 2008 at 3:10 pm
    Try to be a little more organic with the camera wiggle. The seesawing back and forth looks a little too mechanical and likely to induce seasickness. Subtle smooth movements back and forth at varying degrees to give the sense of a hand held camera or that the viewer is floating. Then mix it up a little as you move from position to position to the next title.
    Erik
  • Joey Burnham
    June 17, 2008 at 5:56 pm
    Agreed with the “see-saw” comment. I hard a hard time making it through the who sequence without feeling queasy. A slight initial push is all I would think is needed, as there’s a lot going on.
    Joey
  • Ron Coy
    June 18, 2008 at 10:30 pm
    try experimenting with the wiggle expression on the camera position to get a bit of random motion if you feel you need it. What you have here is too much motion and the rocking, swinging motion is overkill.
  • Eyad Abutaha
    June 21, 2008 at 5:20 am
    I reduced the “see-saw” effect; hopefully it’s better now; I could use the wiggle expression, but my idea was to add different movement to the camera I mean the “see-saw” I didn’t want it a steady move.
    Yes; it looked like a see saw; but hopefully now it is not.
    Thanks guys
