Activity Forums Adobe After Effects Images won’t reconnect (using replace footage) HELP
  • Images won’t reconnect (using replace footage) HELP
    Posted by Jack Nastowski on May 1, 2006 at 12:36 am
    I just got an AE file from a a person running AE 5.5 on Windows. I’m running 6.5 on a Mac.
    The Project contains 60 still images. I have the images on my computer. When the project opens, AE reports the images as missing. I try to replace footage and connect them to their files, but it does nothing after i click “Open”. When I attempt a replace footage and use “find” to retrieve the image- i get this message after I click on “Open”-
    I keep getting the error: “The File format module could not parse the file”
    Any suggestions?
    Your help is wildly appreciated.
    Jack
    E-mail JackNasty333@aol.com
    Steve Roberts replied 20 years, 4 months ago 2 Members · 3 Replies
  • Steve Roberts
    May 1, 2006 at 1:02 am
    Tell us about the file format of the stills. What are they?
    Can you import them directly into a new project as a test?
    Will they open in Photoshop?
  • Jack Nastowski
    May 1, 2006 at 2:20 am
    The files are JPEG’s and TIFF’s. They all open up in photoshop fine.
    In a new AE project, the jpeg’s import fine, but most of the TIFF files get the same error message.
  • Steve Roberts
    May 1, 2006 at 3:36 am
    Perhaps the TIFFs were saved using the PC byte order? Can you open them in Photoshop and do a batch resave to Mac byte order?
    (the choice is in the PS save dialog, after you choose to save as TIFF)
