Activity Forums AJA Video Systems Images goes darker on pause
  • Images goes darker on pause
    Posted by Pierre Tremblay on January 8, 2008 at 8:18 pm
    Hi there,
    I’m using a Kona 2 (driver 3.4) in a G5 dual 2gHz, OS 10,4,11. Whenever I pause in FCP,
    the image goes darker on both my CRT (component) and my LCD (HD-SDI to AJA HDP to
    ACD 23″). This happens whether I’m in SD or HD. How can I correct this?
    Thanks.
    Pierre Tremblay
    Pierre Tremblay replied 18 years, 7 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    January 8, 2008 at 8:55 pm
    What codec?
  • Pierre Tremblay
    January 8, 2008 at 9:00 pm
    It seems to be independent of the codec. Right now I’m in DVCPro-HD,
    but it does the same in SD 8 or 10 bit uncompressed. Is this normal?
    Could it be the analog output format setting (Component SMPTE?EBU N10)?
    Pierre
  • Jeremy Garchow
    January 8, 2008 at 9:05 pm
    No, it shouldn’t be. Try turning off your range check (control-z).
    Jeremy
  • Pierre Tremblay
    January 8, 2008 at 9:09 pm
    Bingo! Thanks.
    Pierre
