Activity Forums Maxon Cinema 4D Images as Material textures to look like Projections
  • Images as Material textures to look like Projections
    Posted by Rose Staff on May 15, 2020 at 4:14 am
    Im trying to make a 3D visualisation of a room with projections on the walls.
    I am placing a still image on the colour – texture channel to represent the artwork that would be displayed.
    I cant seem to get the image textures to glow
    Ive tried putting the image texture also on the luminance channel to give it a glowing effect. Ive also tried using a backlight effect on the luminance channel and putting a light behind the wall.
    These dont seem to be working very well for me.
    For example this is what my renders are looking like:
    This is some examples of what Im trying to achieve:
    Sam Treadway replied 6 years, 4 months ago 3 Members · 2 Replies
  • Jim Scott
    May 15, 2020 at 5:18 am
    Have you tried the “Glow” effect in the render settings?
  • Sam Treadway
    May 16, 2020 at 2:51 am
    Put the image in the luminance channel of the material.
    Set the luminance channel’s color value to white.
    Set the brightness value above the texture field to something above 100% (try 200% to start)
    Set the mix mode at the bottom to Multiply, then slide color Value (the V in HSV) down until you reach your desired look.
