Activity › Forums › Apple Final Cut Pro Legacy › Images and HDV – 720p24
  • Images and HDV – 720p24
    Posted by Franz Krekeler on June 15, 2010 at 8:47 pm
    Hi all creative cows,
    I’m working on a short movie made out of pictures but I always have to render.
    Is there any format or setting where I can use those images without rendering.
    At the moment I use Final Cut’s setting HDV – 720p24 and JPGs with the seize 1280 x 850.
    Any suggestions what format I should use for the images?
    Thanks in advance,
    Franz
    Jerry Hofmann replied 16 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 15, 2010 at 9:06 pm
    Try changing the sequence settings to a ProRes setting instead of HDV… it will not only perform better, it will actually look better. HDV should be avoided at all costs.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
