Activity Forums Adobe After Effects Images added to CS5 timeline are squished
  • Images added to CS5 timeline are squished
    Posted by Jeff Davis on September 23, 2010 at 4:47 am
    I’ve carefully created a number of JPGs and PSDs (both in Photoshop CS5) to match the pixel size of my AE CS5 composition, 1440 x 1080. When I import them, they all appear fine in the comp/footage viewer, and their proportions are listed correctly in the Project panel.
    When I add any of them to the timeline, however, they’re squished into a square. The height is slightly less than 1080 and the width is a lot less than 1440. This happens regardless of whether I import as footage or composition. How do I get them to maintain their size and aspect ratio when adding them to the composition? Thanks.
    Jeff Davis replied 15 years, 11 months ago 60,767 Members · 2 Replies
  • Jeff Davis
    September 23, 2010 at 8:17 pm
    Aah, yes. Thanks very much. I was aware of that issue but just haven’t encountered it yet in anything I’ve worked on. Didn’t think about it hard enough, I guess. It seems to me the most intuitive way to work would be to create an image (in Photoshop or Illustrator, e.g.) at the final resolution of the comp, but with square pixels so it doesn’t look distorted. Then interpret the footage in AE to the comp’s pixel aspect ratio. Any cons to that approach?
  • Jeff Davis
    September 23, 2010 at 11:17 pm
    Thanks for the thoughtful answer, Dave. Have you ever seen a table laying out these relationships for various comp sizes?
