Activity Forums Adobe Premiere Pro ImageRenderer.dll Error / Iris Wipe causes CS6 crash
  • ImageRenderer.dll Error / Iris Wipe causes CS6 crash
    Posted by Jason Twite on March 27, 2013 at 4:48 pm
    Hello,
    I’m experincing a strange error with Premiere CS6. I’ve narrowed it down to occuring seemingly whenever a default Iris Points wipe with a border width transitions between two HDV clips.
    The generic “error has occurred and must close” message appears and there’s no way around it.
    I’ve trashed preview files and cleaned Media Cache, but no difference.
    Tried the same method with SD footage in 16:9 NTSC preset sequence and it hasn’t crashed so far.
    Searched around Adobe Forums, Googling and no clear answer. Any help?
    THANK YOU!
    This is the Win7 error log summary:
    Faulting application name: Adobe Premiere Pro.exe, version: 6.0.3.0, time stamp: 0x505748bf
    Faulting module name: ImageRenderer.dll, version: 6.0.3.0, time stamp: 0x505737fa
    Exception code: 0xc0000005
    Fault offset: 0x0000000000194d12
    Faulting process id: 0x1128
    Faulting application start time: 0x01ce2b076bec6441
    Faulting application path: C:Program FilesAdobeAdobe Premiere Pro CS6Adobe Premiere Pro.exe
    Faulting module path: C:Program FilesAdobeAdobe Premiere Pro CS6ImageRenderer.dll
    Report Id: 1516e1db-96fb-11e2-aaf2-50e549ba8016
    System Settings:
    Win7 64-Bit
    Premiere 6.0.3
    AMD Phenom II X4 965 Processor 3.4ghz
    16 GB RAM
    Nvidia GeForce GT440 (not optimized for CUDA acceleration with MPE)
    1680×1050 resolution monitors; no external playback control.
    Footage details via MediaInfo:
    Format : MPEG-TS
    Format_Commercial_IfAny : HDV 1080i
    File size : 475 MiB
    Duration : 2mn 27s
    Start time : UTC 2013-02-13 09:32:54
    End time : UTC 2013-02-13 10:41:29
    Overall bit rate : 27.0 Mbps
    Maximum Overall bit rate : 33.0 Mbps
    Encoded date : UTC 2013-02-13 09:32:54
    Video
    Menu ID : 100 (0x64)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High 1440
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Codec ID : 2
    Duration : 2mn 26s
    Bit rate : 25.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.536
    Stream size : 443 MiB (93%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Premiere Sequence settings:
    HDV 1080i preset
    Max bit depth and Max Render Quality not checked
    Jason Twite replied 13 years ago 2 Members · 2 Replies
  • James Kumorek
    September 9, 2013 at 11:50 am
    I’m seeing the same problem — as soon as I try to change the border width on the Iris Star transition to something greater than 0, Premiere crashes. Did you find a solution to this problem?
  • Jason Twite
    September 9, 2013 at 6:10 pm
    Hi James,
    No, I never found a solution to this problem. Ended up downloading Premiere CC, but don’t know if I’ve used an Iris Wipe since this problem started.
    Certainly wish there were more definitive answers to obvious bugs like this.
