Activity Forums VEGAS Pro Image Transition
  • Image Transition
    Posted by Cg208cm on October 5, 2005 at 9:35 pm
    I have imported roughly 250 images into Vegas and I want to globally overlap/fade each image. Is it possible to do this for all at once or must I do it for each individual image?
    Edward Troxel replied 20 years, 11 months ago 3 Members · 3 Replies
  • Mary Waitrovich
    October 5, 2005 at 10:09 pm
    go to the editing tab of Preferences and set the still image duration and overlap as you like. Then select and drag all images to the timeline at once. They will be automatically crossfaded.
    Mary Waitrovich
    UW-Madison
  • Cg208cm
    October 5, 2005 at 11:43 pm
    Thank you sooo much
  • Edward Troxel
    October 6, 2005 at 3:21 am
    If you need to create the overlaps AFTER they’re already on the timeline, scripting will do it for you.
    Edward Troxel
    JETDV Scripts
