Image Tracker – Whats the best one?
Posted by Will Brown on February 8, 2011 at 2:42 amHi Guys,
Can anyone recomend a decent image tracker for Veags Pro 9?
Thanks.
Will.Will Brown replied 15 years, 7 months ago 4 Members · 7 Replies -
Nigel O’neill
February 8, 2011 at 2:57 amWhat do you mean, like an library catalogue tool?
Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Will Brown
February 8, 2011 at 3:04 amSorry, I have done some research and I see that Boris is the standard.
I have Boris FX9.2 and I am trying to motion track some footage.
When I add Boris to the clip, the stand alone Boris interface pops up.Does anyone know of any good tutorials out there?
I have googled it, but it’s all about BCC not BFX.
I am using Vegas Pro 9.Thanks.
Will. -
John Rofrano
February 8, 2011 at 12:58 pm[Will Brown] “I have give up.
I’ll do it in After Effects!”Boris FX isn’t fully integrated into Vegas yet. You need to do motion tracking in standalone mode just like you would with After Effects and then render in Vegas. This is the exact same workflow as After Effects so I’m not sure why you would give up.
You should take a look at Boris Continuum Complete 7 for Vegas Pro 10. It is fully integrated into the Vegas workflow. Here is a tutorial I did on the motion tracker:
BCC7 Motion Tracking in Vegas Pro 10
Also check out: Match Move in Sony Vegas Pro~jr
http://www.johnrofrano.com
http://www.vasst.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Will Brown
February 9, 2011 at 11:08 amSuper John, thanks.
I have Vegas 10 but not BCC7 yet.
As I have AF CS5, I obviously don’t want to buy BCC7 just for the tracking option.I will keep in mind.
Thanks.
