Image to dots transition
Hi Guys, I was wondering how you would make to following animation – https://vimeo.com/61042884
The part were some dots become an image.
Im starting out with Trapcode Form and using that as a ‘mask’ over the image. If somebody has a better suggestion, im glad to hear it. thanks.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
