Activity › Forums › Maxon Cinema 4D › Image Texture is distorted
  • Image Texture is distorted
    Posted by Kenneth Rodriguez on June 15, 2019 at 4:11 pm
    Hi! I’m new to Cinema 4D and I’m trying to make a 3D smartphone model. When I make a texture for the screen of the smartphone (which is png file) and apply it to a polygon, the image is distorted even when rendered.
    Here is the image I used for the texture:
    And this is the result I’m getting:
    I hope someone can help me!
    Thanks in advance!
    Brian Jones replied 7 years, 3 months ago 2 Members · 1 Reply
  • Brian Jones
    June 15, 2019 at 6:51 pm
    unfortunately your image covers the most important info – what is the Texture Tag/Projection set to? if it’s UVW your UV’s are kind of goofed from the construction if it’s somethings else it should probably Flat or UVW (depending).
