Activity Forums Adobe After Effects Expressions Image swinging at end of pendulum
  • Dan Ebberts
    May 8, 2009 at 4:56 pm
    That’s really a double pendulum. The math for that actually produces pretty chaotic results, which probably isn’t what you want. You could probably still automate it by triggering a second pendulum expression based on the angle of the first one, but it might be more trouble than it’s worth.
    Dan
  • Ryan Hamilton
    May 8, 2009 at 6:24 pm
    Ok, if the math and procedure will get to crazy I guess it may just be easier to key frame the pictures manually. I have 50-60 of these swinging pics in a room, so I thought an expression would speed things up so I only changed a couple values for each image, and could have different swinging speeds and rotation values. Thanks anyways.
    Ryan
