Activity Forums Apple Final Cut Pro Legacy image stutters before transition
  • image stutters before transition
    Posted by Tom Fino on May 12, 2015 at 4:01 pm
    I’m using FCP 7, editing footage that was shot with a Sony A7-S at 24fps. I converted it to QuickTime H.264 files. Files are on an external hard rive.
    On the timeline, whenever the player head approaches the end of one clip, the image in the outgoing clip hesitates or stutters just before the transition to the next clip. (The same clip plays fine with no stutter in the Viewer window.)
    I’d appreciate any help you could give. Thanks.
    Shane Ross replied 11 years, 4 months ago 2 Members · 1 Reply
  • Shane Ross
    May 12, 2015 at 5:19 pm
    There is no plug in to allow it to be brought in via Log and Transfer. This must be converted with an outside converter. EditReady does this well, as does Bulletproof. Yes, you need to convert to ProRes 422…FCP and H.264 don’t mix.
    Shane
    Little Frog Post
