Activity Forums Apple Final Cut Pro Legacy Image Stabilize Plugin
  • Image Stabilize Plugin
    Posted by Michael Brodner on February 13, 2008 at 7:13 pm
    Is there an image stabilizer or “steady cam” like plugin in Final Cut Express 4? I know there’s one in the new Final Cut Pro but I’m currently running express. I have a handheld shot that I would like to make look a little more fluid. Thanks
    Bones
    Doug Cabot replied 14 years, 7 months ago 8 Members · 10 Replies
  • 10 Replies
  • Thaxter Clavemarlton
    February 13, 2008 at 7:43 pm
    I have this one that works as a stand-alone app with Quicktime files.
    https://mac.softpedia.com/get/Video/iStabilize.shtml
    It’s kind of amazing, actually.
    Free demo download.
  • Michael Brodner
    February 13, 2008 at 7:54 pm
    interesting. so its a whole other program huh? Is it easy to use? How big’s the learning curve? I want to avoid leaving final cut for this kind of stuff as much as possible. I already hate having to bounce back and forth between after effects and final cut. Rendering takes forever.
    Bones
    February 13, 2008 at 8:07 pm
    [Michael Brodner] “interesting. so its a whole other program huh? Is it easy to use? How big’s the learning curve? I want to avoid leaving final cut for this kind of stuff as much as possible. I already hate having to bounce back and forth between after effects and final cut. Rendering takes forever.
    Sorry.
  • David Peralta
    February 13, 2008 at 11:05 pm
    What Version of FCP are you using? I know its included with vers 6.. but w/ FCP 5 its not.
    hmm… I wonder what this button does…
  • David Mcgiffert
    February 13, 2008 at 11:56 pm
    There is also a very decent stabilizer in
    the new Motion in FCS2.
    But I guess that’s not much help either,
    but fwiw.
    David
  • Bryan Dicerb
    February 14, 2008 at 1:11 am
    he said in the original post he knew it was in the new final cut, but he had express. So there is no button to push.
  • Michael Brodner
    February 14, 2008 at 3:09 pm
    As I said in my post, Im not using Final Cut Pro, Im using Final Cut Express 4
  • Jason Porthouse
    February 15, 2008 at 6:35 pm
    Michael,
    iStabilise is very simple, very intuitive and very powerful. You’ll be up and running in a very short time.
    Workflow to FCP is easy – I usually export a shot as self contained, bring it into iStabilise, save it out with ‘smooth’ in the title and re-import.
    There’s a demo version available – give it a try!
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
  • Philippe Bertrand
    October 26, 2011 at 8:36 pm
    nice! is it possible to use it to analyze video waves (frequency, shape, etc)
  • Doug Cabot
    February 10, 2012 at 4:47 pm
    Newer versions of iMovie have a Stabilization filter. It’s one reason (the only one I can think of) to use iMovie, but it’s a good one.
    1. Import the source file (iMovie copies it into the project, unlike FCE/FCP, which only references the clip).
    2. Drag the clip (or some part of it) from the Events to the Project Browser window.
    3. Choose File/Analyze/for Stabilization. Then double click the clip and select Stabilize, or Smooth (I forget).
    4. Export (under Share menu) “using Quicktime.”
