Activity › Forums › Apple Final Cut Pro Legacy › image stabilization
image stabilization
Posted by Brigitta Boccoli on December 1, 2007 at 4:33 amHey guys,
a question.
I have a couple of shoots from helicopters… we did not use any steady-cam or an external stabilization system.
Now the shooting is so so, vibrations here and there and I was trying to fix it.
I have been playing with final cut tools to find a workaround.
I enlarged the clip size of a 3% (103) and kept the subject in the center using X and Y, basically mooving back the image every time it jumped away.Any better tool you can suggest for image stabilization?
Dylan Reeve replied 18 years, 9 months ago 11 Members · 13 Replies -
Shane Ross
December 1, 2007 at 5:05 am[JeremyG] “Use smoothcam if you have FCS2.”
Same feature in Shake…iffin you have Shake but not FCS2.
Iffin you don’t have either…time to get one.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Brigitta Boccoli
December 1, 2007 at 6:25 am
for same feature do you mean enlarge the image and play with the position of the subject or some shake`s special power tool?Not familiar with shake yet… but I have to get it anyway for color correction
13
December 1, 2007 at 6:32 am[massimiliano] “for same feature do you mean enlarge the image and play with the position of the subject or some shake`s special power tool? “
NO, Smoothcam is a new feature in FCS2. It douse the image stabilization for you.
Shane Ross
December 1, 2007 at 6:36 amShake is NOT a color correction tool. It is a COMPOSITING tool, with other handy features. And yes, FCP 6 DOES (not “douse” zrb…stop that) include that. I just offered Shake in case you didn’t want to upgrade….just another option that DOES image stabilization.
(ribbin’ ya zrb…)
Shane
Brigitta Boccoli
December 1, 2007 at 6:45 amalright,
I promise I wont use shake for color correction! But definitely for fixing the up and down -
Uli Plank
December 1, 2007 at 7:44 amIf you don’t know Shake yet, it’s much easier to upgrade to FCS 2. You’ll get SmoothCam in FCP (and it works great!) plus Color, an excellent CC tool.
Regards,
Uli
David Roth weiss
December 1, 2007 at 9:14 am[zrb123] “It douse the image stabilization for you.”
Why the heck would it pour water on the image stabilization?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Rafael Amador
December 1, 2007 at 9:26 amAs somebody posted here just the FC Smoothcam makes worth the upgrade to FCS2.
The results are amazing.
But few tips to use it:
Don’t use it directly over your master clips, because will analysed the whole movie.
Edit your shoots in a sequence trying to clean all the images with too much movement.
After you can use the media manager to export all the shoots to a new projet. Use the Smoothcam in this second project. Only this footage will be analysed.
RafaelPPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE -
Jason Porthouse
December 1, 2007 at 11:17 amIf you can’t go to FCS2 (and it is worth it) then an alternative that works well is iStabilize. A stand-alone app that is simple and effective… not connected, just a happy user. I’ve corrected heli shots with it and it works well. Learning curve isn’t too bad either…
50 of your ‘merkin dollars I believe.
J
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
